It is currently Tue Feb 18, 2020 9:08 am
PostPosted: Tue Jan 21, 2020 1:03 pm
EDIT :
Dear support,
Would you be so kind to post a working example of python code to save an archive while calling CODESYS.exe with --noUi option?
Thank you in advance!
EDIT
Dear Forum,
When we run a testscript embedded in the CODESYS IDE , we can call
projects.primary.save_archive(path, name)
and the script will save our project as an archive.
When we run this same test script called agains the CODESYS IDE --noUI, the script fails and returns:
Error: Object reference not set to an instance of an object
With kind regards
PostPosted: Tue Jan 28, 2020 11:49 am
Hi.
Which version of CODESYS does throw the error?
Martin
PostPosted: Tue Jan 28, 2020 1:12 pm
Currently we use 3.5.13.10
PostPosted: Wed Jan 29, 2020 9:36 am
Hi.
Does the error also occur with CODESYS 3.5.15.30?
Martin
PostPosted: Wed Jan 29, 2020 11:39 am
Sadly, we cannot use that version, because it is installed in a offline environment.
Regards,
Hermsen
