It is currently Mon Jan 21, 2019 12:41 pm
PostPosted: Wed Feb 01, 2006 11:48 pm
I have a descrete event simulation model of a manufacturing line. The simulation tool has an integrated OPC client for accessing the model's I/O signals.
I am thinking to build a training system for teaching 1131 programming with a soft plc tool over this simulation system.
My question is, could I use codesys soft plc to write a control application, which reads process measurements and writes control signals to the simulation model via codesys opc server?
sensor -> simulator opc client -> codesys opc server -> soft plc input
and
soft plc output -> codesys opc server -> simulator opc client -> actuator
Thanks!
JuPe
 Post subject:
PostPosted: Mon Feb 06, 2006 12:09 pm
Yes, of course such a configuration is possible.
You can use the CoDeSys OPC server to communicate with any OPC client in writing and reading mode. The CoDeSys SoftPLCs (both CoDeSys SP RTE with hard real time properties as well as PLCWinNT with soft real time properties) can communicate with any OPC client via the CoDeSys OPC server. As the OPC standard is not very strict in special cases there might nevertheless be some problems. Anyway CoDeSys is tested for the most important OPC clients. In case of problems please do not hesitate to contact the 3S support hotline.
The same configuration is used when there is a data exchange with other OPC clients, e.g. visualisation systems.
Roland Wagner
Moderator
PostPosted: Fri Oct 01, 2010 7:33 am
Codesys can act as OPC server and communicate with OPC client.
Could we also use CoDeSys as an OPC client and communicate with an opc server?
Regards
Cyril
PostPosted: Tue Oct 05, 2010 2:08 pm
So far CoDeSys only has an OPC server and cannot act as an OPC client.
There is a proprietary interface available which can handle both directions (PLCHandler), but this is of course no longer OPC.
Roland Wagner
Moderator
