It is currently Sat Feb 22, 2020 2:30 am
PostPosted: Tue Jul 02, 2019 6:36 am
Hello. I have difficulties to run the OPC server of my pigeon PLC (raspberry pi compute inside) with runtime 3.5.14.20.
The UaExpert windows "Add Server" :
see attachment n°3
The UaExpert windows error :
see attachment n°2
The Codesys log window:
see attachment n°1
I have a questions :
1) Which configuration file should I use?
"/etc/CODESYSControl_User.cfg" or "/etc/CODESYSControl.cfg"
2) What configuration in this file
[CmdOPCUA]
NetworkAdapter = eth0
NetworkPort = 4840
OU
[CmpOPCUAServer]
NetworkAdapter=eth0
NetworkPort=4840
3) What means the errors in Codesys log and UaExpert log ?
Thank you
Note:
When I do a Codesys Win V3 project, everything works.
PostPosted: Wed Jul 03, 2019 5:42 am
Hi. I found the solution.
In UaExpert OPC client, after add the server, display the properties of this server and replace the "EndPoint URL" :
opc.tcp://hostName:4840 by opc.tcp://IpAdress:4840
Now, it works
