It is currently Tue Feb 18, 2020 2:19 pm
PostPosted: Wed Nov 21, 2018 2:15 pm
Hello!
I want to know if there is any way to configure some parameters on the OPC-UA server. I need to configure the security of the server. First of all, I created the certificates of the server and I set up an encrypted connection with UaExpert following the steps of the page:
https://help.codesys.com/webapp/_cds_ru ... n=3.5.13.0.
But, when I insert the server endpoint in UaExpert, I see that I can communicate with the server using three types of Security Settings:
None - None
Basic256Sha256 - Sign
Basic256Sha256 - Sign & Encrypt
I got to communicate perfecty with certificates, but I want to appear only Basic256Sha256 - Sign&Encrypt there, because I have seen that I can communicate perfectly with the server using the None - None configuration without having to use any type of certificate (and this I don't like it).
Where can I configure this settings? Is there any configuration file in the Codesys program or is it any in the Raspberry?
Thanks!!
PostPosted: Mon Dec 03, 2018 3:04 pm
with 3.5SP14 release (17th December 2018)
this will be the following setting the CODESYSControl_User.cfg
[CmpOPCUAServer]
SECURITY.CommunicationMode=SIGNED_AND_ENCRYPTED
