It is currently Fri Dec 13, 2019 4:31 pm
PostPosted: Fri Nov 09, 2018 3:19 pm
Hello, I am trying to get a test rig which tests different protocols. I know the Raspberry Pi supports ProfiNet. But I have been asked to use the Siemens PLC to control the device under test.
My thought was to setup an OPC server on the Siemens PLC and a OPC client on the Raspberry Pi. All I can find is a Codesys OPC server for Raspberry Pi. The Siemens PLC OPC software is server only.
Could two OPC servers talk to each other? I have installed a OPC client on the Raspberry Pi, which can access the Codesys OPC server on the localhost.
Snap7 wouldn't install, so gave up on that.
PostPosted: Fri Nov 09, 2018 3:33 pm
using OPC UA Server on Raspberry PI...
Is it possible to have a OPCUA CLient on siemens side?
PostPosted: Fri Nov 09, 2018 3:48 pm
It says here
https://w3.siemens.com/mcms/automation- ... fault.aspx
In the future a client will be included. I found in the Siemens forum that it may be included in V15 of their Tia portal. But Siemens' website doesn't say that at all.
