Dear all
I have two questions....
1. Can the CODESYS OPC DA Server SL make connection with a CodeSys SoftPLC (Control Win or a Control RTE SL) ?
2. In the CODESYS OPC DA Server SL configuration, see picture, according to the manual the "PLC name (recommended) or address" should be set. The manual also refers to this as a node. But how do I find out the name or address of a specific SoftPLC (I run two simultaneously)?
I have tried with various guesses. And tried to connect to the DA server without success. All runs on the same PC. From the picture I would guess the address is 004 or 0301.A026.
Thank you!
