It is currently Fri Jan 24, 2020 5:36 pm
 Post subject: OPC-server
PostPosted: Wed Oct 26, 2005 10:16 am
I'm configuring OPC-server and "talk" to this from Intouch via OPCLink (Wonderware). The log-file at the OPC-server looks to be fine, I can browse all items from OPCLink, but get no values. Any out there have any ideas? Bryn. OPC-logfile looks like this:
Filter=0xffffffff
(26.10.2005, 09:44:43.484) Server 2.3.9.1 started
(26.10.2005, 09:44:43.484) UpdateRate[ms]=500, PublicGroups=1, SyncInit=1, LogEvents=1
(26.10.2005, 09:44:43.484) 1. Reconnect to <PLC1>
(26.10.2005, 09:44:43.500) [PLC1]: ::ConnectGateway(): m_ulGatewayChannels=1
(26.10.2005, 09:44:43.500) Gateway Version: 2.3.5.1
(26.10.2005, 09:44:45.343) <PLC1> Reconnect successful, ProjectName='BSY1.pro'
(26.10.2005, 09:44:45.343) Timeout[ms]=10000, BufferSize[B]=0, Waitime[s]=10, Reconnecttime[s]=15
(26.10.2005, 09:44:45.343) Motorola=0, NoLogin=0
(26.10.2005, 09:44:47.531) <PLC1> ProjectID matched, Project <BSY1.pro>: PLC=519306, SYM=519306
(26.10.2005, 09:44:47.531) <PLC1> 7 symbols loaded
(26.10.2005, 09:44:47.546) Client attached to server
 Post subject:
PostPosted: Thu Nov 03, 2005 3:56 pm
The logfile looks good, but there are no active items requested by the client.
Do you have added the items into a group in OPCLink? Then you should see number of active items > 0 in the opc-server logfile and you should see the item values.
Regards,
Armin
 Post subject: OPC-server and OPCLink
PostPosted: Fri Nov 04, 2005 8:28 am
Here are some stuff from the WWLogger
1550 04.11.2005 08:07:44 1504 1556 Info VIEW Wonderware I/O Server Toolkit for Windows NT - Version 7,2,0,0
1551 04.11.2005 08:07:45 1620 1492 Info OPClink TRACE: add OPC group (hClientGroup=0x00000002, hServerGroup=0x00000001) to: test.pro on CoDeSys.OPC.02
1552 04.11.2005 08:07:45 1620 1492 Info OPClink TRACE: attaching group to: test.pro
1553 04.11.2005 08:07:45 1620 1492 Info OPClink ERROR: cannot add OPC item: PLC_PRG.VERDI1 (type=0x0003, hr=0xc0040008, hCli=0x01000000, hSrv=0x00000000) to group on topic: test.pro
1554 04.11.2005 08:07:45 1620 1492 Info OPClink The item ID doesn't conform to the server's syntax.
1555 04.11.2005 08:07:45 1620 1492 Info OPClink ERROR: cannot add OPC item: VERDI0 (type=0x0004, hr=0xc0040008, hCli=0x01000001, hSrv=0x00000000) to group on topic: test.pro
1556 04.11.2005 08:07:45 1620 1492 Info OPClink The item ID doesn't conform to the server's syntax.
1557 04.11.2005 08:07:49 1620 1492 Info OPClink Build Information for Server "CoDeSys.OPC.02": Build Number=9. Version Number: Major=2; Minor=3.
1558 04.11.2005 08:07:54 1620 1492 Info OPClink GetStatus for server "CoDeSys.OPC.02": state: 1
As you can see there are some problems with the item-syntax written in Intouch. Corresponding to thes error messages I use the following item-syntax:
VERDI0 use rVERDI0
VERDI1 use iPLC_PRG.VERDI1
STATUS use STATUS
I've used Intouch a lot of times with OPSLink against other OPC-servers and prefix the items with i - r - d - m according to the OPCLink-rules of addressing items.
