It is currently Sat Dec 07, 2019 3:45 pm
PostPosted: Thu Mar 02, 2017 10:24 am
Hi all,
I have a problem with the OPC communication. I'm trying to install a communication between two devices, a PLC and an HMI.
I create a Datasource Manager and then a Datasource. If I use the option "Application V3" I have a problem with the arrays (see image attached).
If I create the same configuration but with Symbolic access I don't have any problem and all values are correct.
Is this a known issue or I misconfigured something?
Thank you, regards.
Massimo.
PostPosted: Tue May 09, 2017 10:01 am
No one can help me?
