It is currently Wed Oct 18, 2017 11:03 pm
 Post subject: OPC Client not connect.
PostPosted: Thu Sep 19, 2013 9:55 am
I have properly configured OPC Configurator using same connection CoDeSys (test ok). But application vb and Matrikon only work if is open CoDeSys and PLC is online. My CoDeSysOPC is v2.3
This problem sometimes resolves without reason. :shock:
sorry my english.
thanks
PostPosted: Fri Sep 20, 2013 7:41 am
Hi!
Have you checked that the windows 'service' opcenum and the rest of the software is started by automatic.
/Torbjörn
PostPosted: Mon Oct 21, 2013 11:37 am
Yes, the service opcenum is successfully started,
PostPosted: Mon Dec 09, 2013 10:17 am
The problem persists, help me please?
PostPosted: Fri Mar 04, 2016 11:35 pm
Is your Codesys OPC and client on the same PC? Or is the client on a different PC?
From my experience with Codesys OPC, I can only get connected when the OPC client and server is on the same PC.
If client and server is on 2 separate PCs, I can not get the client to connect. I looked through all possible documentations on EnumOPC, DCOM, user privileges, etc... If anyone has successfully done this, I would like to know how it was done.
PostPosted: Thu May 12, 2016 7:53 am
Hi guys,
I have the same problem, is the OPC server v3 support clients from different PC?
Although i see the available tags form Server the quality is Bad
