FAn - 2013-07-16
I'm facing a serious problem with the opc symbols.
When in configure symbol file I select "Export structure components" those are exported on the same "root" as the owner instance without any directories instead of nested inside the instance.
Can I change this behavior? How
I'm using the ABB compact hmi 800 where I prepared some object types that need to have the opc data structure matching theirs, so I need to fix this.
