It is currently Sat Oct 19, 2019 3:17 am
PostPosted: Thu Jun 13, 2019 2:55 pm
We are currently trying to connect the OSIsoft PI System to a CoDeSysOPC-Server using the PI OPC DA interface.
There is also an Stange ECS application connected to this CoDeSysOPC-Server.
When the Stange ECS application is connected to the CoDeSysOPC-Server, we are unable to connect with the PI system.
Has anyone experienced something like this or would have any suggestions for me?
PostPosted: Fri Jun 21, 2019 1:42 pm
sounds like the max Client is exeeded ( Default is 4)
If i understand it, you do not get values from the CODESYS PI to your OPC DA server connected Client, right?
You could extend the Client by adding to the
/etc/CODESYSControl_User.cfg
[CmpChannelServer]
Buffersize=1600000
MaxChannels=8
do not forget to restart the Pi after this change.
PostPosted: Fri Jun 21, 2019 5:43 pm
Edwin, can you explain "Buffersize=1600000"? What the buffer, which dimension of value (bytes?).
"Channel" represents only CODESYS OPC connection to PLC? Or any connection like IDE connection, web-visu connection, etc.
Make CODESYS great again
PostPosted: Sat Jun 22, 2019 7:01 am
 BUFFERSIZE is the overall amount of memory to be used by all channels
MAXCHANNELS defines the number of channels that may be handled
 concurrently.
Since each channel needs separate send and receive channels
the available communication buffer is BUFFERSIZE / (2*MAXCHANNELS)
- Webvisu
- OPC UA
- OPC DA
- CODESYS
each occupy one channel...
PostPosted: Sat Jun 22, 2019 7:13 am
Thank you for explanations.
PostPosted: Fri Jun 28, 2019 11:23 am
Hi Edwin
Thanks for your response. I have searched the etc folder an it does not contain the config file or any files from CODESYS.
Could you please tell me where exactly I can locate this file?
Regards
Ed
PostPosted: Sun Sep 01, 2019 7:40 pm
which version do you have installed on the PI?
(CODESYS runtime 3.5.x.x)
