It is currently Sun Oct 20, 2019 10:30 am
 Post subject: Creating Unit Test
PostPosted: Thu Aug 01, 2019 7:36 am
Hello Fellas,
I have a problem.
I am using the Test Manager for the first time.
I am able to use Test Cases without any problem.
But, when I try to create a simple unit test using test tables, I got this fault:
"Attempt to write an object with read-only access. (Object: 'PLC_PRG [Device: Plc Logic: Application]"
I checked my PLC_Prog , to make sure that everybody can have all access to this routine, but I still receive the same messages, I tried using the runtime and the simulation and the results are the same.
Can anyone help me? Unfortunately, I couldn't find this fault in anywhere.
Thanks a lot
 Post subject: Re: Creating Unit Test
PostPosted: Thu Aug 01, 2019 8:00 am
Hi.
Is the text from a compile message in the Message view?
Martin
PostPosted: Thu Aug 01, 2019 9:23 pm
M.Keller wrote:
Hi.
Martin
I think this attached image can help
PostPosted: Mon Aug 05, 2019 6:53 pm
Anyone?
I follow the webinar to create the unity test using a table, also I create a new project and always got this fault, I am trying to understand which step I am missing.
