It is currently Sun Aug 18, 2019 6:04 pm
PostPosted: Mon Jul 08, 2019 3:02 pm
Hey,
I'm struggling with the properties of a FunctionBlock in CODESYS V3.5.
I have a FB A, which instances two different FBs B and C.
Now I want to change a property from FB B in FB C.
The error message says, that the FB B is not an entry of FB A.
If I write my own setter-method in FB B for the property and call it in the FB C it works and I don't get an error message.
Can anybody explain why I'm able to call a function from the other FB but not a property?
Thank you for your help!
Fabian
PostPosted: Mon Jul 08, 2019 7:00 pm
Are you giving FB_C a reference to FB_A's instance of FB_B?
FB_C knows nothing about FB_B, unless you define an FB_B instance in FB_C. But, since you want to have FB_C specifically affect FB_A's instance of FB_B, then you need to setup FB_C to have a REFERENCE TO FB_B, instead of it's own instance of FB_B.
Silly example:
Create FB_B with a simple Property that maps to a local variable...
FUNCTION_BLOCK FB_B
VAR_INPUT
VAR_OUTPUT
   _Local : BOOL;
PROPERTY Prop1 : BOOL
Get routine:
Prop1 := _Local;
Set routine:
_Local := Prop1;
Now setup FB_C so it can take somebody else's instance (aka REFERENCE TO FB_B). You could also do POINTER TO FB_B or use an interface... I will use REFERENCE TO...
Here, FB_C will set FB_B's property "Prop1" to match "DoIt".
FUNCTION_BLOCK FB_C
VAR_INPUT
   DoIt : BOOL;
   refB : REFERENCE TO FB_B;
VAR_OUTPUT
refB.Prop1 := DoIt;
Now create FB_A that creates instances of both FB_B and FB_C and does something really silly...
FUNCTION_BLOCK FB_A
VAR_INPUT
VAR_OUTPUT
   MyB : FB_B;
   MyC : FB_C;
   Count : INT;
Count := Count + 1;
IF Count > 20 THEN
   Count := 0;
IF Count >= 10 THEN
   MyC(DoIt:=TRUE, refB:=MyB);
ELSE
   MyC(DoIt:=FALSE, refB:=MyB);
And call FB_A from PLC_PRG...
PROGRAM PLC_PRG
   MyA : FB_A;
MyA();
Scott Cunningham
KEB America, Inc.
www.kebblog.com
www.kebamerica.com
