canOpen Faulhaber drive
2019-07-05
2019-07-08
  • mos89@yahoo.com - 2019-07-05
    Hi
    I try to use a Canopen motor with embedded canOpen Position drive.
    I use that drive on other machine or via the motion manager tool from faulhaber.
    My drive Canopen mapping is changed by Codesys,
    i set in codesys the following config after connecting the drive to my codesys master my Canopen mapping is changed:
    IMG: codesys can2.png
  • mos89@yahoo.com - 2019-07-08
    after erasing and rebuilding everything my pdo mapping is ok
    but when i try tor write a value RPDO3 target velocity Can object stay at 0
    when i look at the can trace my object 302 is never sent from my codesys master
    how to set up codesys to sent can frame when my codesys variable change value
    IMG: codesys can3.png
