It is currently Sat Feb 22, 2020 11:55 pm
PostPosted: Fri Sep 22, 2017 9:05 am
How can I edit the parameters of a library that is referenced in my library?
PostPosted: Sun Sep 24, 2017 1:22 pm
In version 3 it is different than version 2 where you would just redefine the constant. You must open the library manager, open the library with the parameters, view the parameters. Now you can enter in your own value.
Scott Cunningham
KEB America, Inc.
www.kebblog.com
www.kebamerica.com
PostPosted: Tue Sep 26, 2017 6:47 am
Dear Scott,
Thank you for your answer. But this does not work. As you can see in the picture below I have referenced MyLib1 library in MyLib2 library and the parameters from MyLib1 are not editable. Maybe it's a bug or maybe this is how is supposed to work, could not find anything in the Online Help.
PostPosted: Tue Sep 26, 2017 7:22 am
you need to use the 'space key' on your Keyboard or make y double click by mouse
this make the line editable.
One mouse click is not enough ;-)
PostPosted: Tue Sep 26, 2017 7:30 am
Hi Edwin,
I know that this is how is supposed to work.
In your example the value column is flagged as editable. If you look in my example the value column is flagged as not editable and I don't understant why.
PostPosted: Tue Sep 26, 2017 1:24 pm
my screenshot is from the project not from the library!
Add the library to the project and edit the paramter in the project project which is using your library.
Changing this in the library makes not really sense.
Chaning parameters in an library (which is in another library) is not supported. (like in your screenshot)
PostPosted: Wed Sep 27, 2017 7:16 am
Thank you for your answer!
Actually it makes sense, at least in my case. For example, in my library I have a referenced the MySQL library from Store and I can't change the maximum number of rows which is given as a Parameter, because Codesys does not allow me to edit parameters of a library referenced by another library. But if it can't be done then I will try to find another solution.
PostPosted: Wed Feb 07, 2018 9:35 am
Hello Ciprian,
I just have the same issue with the not editable parameter list with using MySQL-Library in my own created library.
Have you already found a possibility how to make the parameter list editable?
Thanks a lot in advance for your reply.
PostPosted: Wed Jun 19, 2019 11:24 am
Hello Edwin,
Dynamic memory management is prohibited in some applications.
However, things like the size of arrays need to be customizable.
Parameter lists are a useful way to do this.
This applies to the use of libraries in other libraries as well as in applications.
The ability to change the values of parameter lists in these use cases would be very helpful:
  1. Library development:
    Use of another library.
  2. Application development:
    Use of a child library referenced in another library.
    Example:
       VAR
          MyVar: NAMESPACE1.NAMESPACE2.FB_Pou;
       END_VAR
Conclusion:
Every library project and every application project should be able to change the values of parameter lists of the referenced libraries and their child libraries.
@Codesys: Is this extension conceivable? If impossible, what is the alternative?
Thanks a lot!
Users browsing this forum: andre_teprom and 2 guests
