I want to use several raspberry pies.
I want to make multiple raspberry pies work in one of the codesys.
Is it possible? Tell me how to do it if you can.
I would appreciate it if you also let me know if you can visualize the data communicated between the raspberry pies.
I look forward to hearing from advanced users.
right click at the project name in the tree and choose "Add device".
There you can add as much RPI's you want.
Be carfull and set the Application of this Pi active, you want to work on and generate the code/download to the device. Rightclick to Application and "Set Application active". The active App is shown on bold letters. To communicate from PI to Pi search for network variables in the HELP and have a look at the example in the store: https://store.codesys.com/network-variables.html m
Originally created by: kjsys1202@naver.com
Technically this it is possible yes. What would you like to achieve, i.e. why do you want to do that?
Originally created by: D. Kugler
