Author |
Message |
MichaJ
PostPosted: Thu Apr 18, 2019 7:14 am |
Hi, I'm having problems running the PackageManagerCLI.exe using Codesys V3.5 SP12 Patch 6. I execute the PackageManager as part of a python script with following command:
"C:\Program Files (x86)\Festo\CODESYSV3.5.12.6\CODESYS\Common\PackageManagerCLI.exe" --profile="CODESYS V3.5 SP12 Patch 6 pbF" --install="./CMMT-AS_PointToPoint_3.5.10.31.package"
After executing I receive the error message "access denied":
Initialisiere... Der Zugriff auf den Pfad "C:\Program Files (x86)\Festo\CODESYSV3.5.12.6\CODESYS\ PackageDB\FileStorage\CurrentInstall.log" wurde verweigert.
Running the PackageManagerCLI with SP10 Patch 4 has no issues! How can I solve this problem? Thanks a lot!
Top |
chmm
PostPosted: Tue Nov 12, 2019 2:37 pm |
Hey MichaJ,
it seems, that there are some problems with your admin rights at windows 10. Try to run your application as administrator. I had the same problem. After I start my jenkis slave node as administrator it works.
Best regards, chmm
Top |
