https://forum.codesys.com/
PFC200. Firmware ver 12 with Codesys 3.5 SP14.1. ipkg not found
https://forum.codesys.com/viewtopic.php?f=11&t=9653
Page 1 of 1
Author:  arv [ Wed Apr 03, 2019 1:52 pm ]
Post subject:  PFC200. Firmware ver 12 with Codesys 3.5 SP14.1. ipkg not found
I had installed Wago firmware //Firmware Release 03.00.35 (12)// on 750-8203. And after that I had try to install Codesys 3.5 SP14.1 runtime. At the end of installation the message "ipkg not found" was appeared.
Finally I tried //Firmware release (11)// and Codesys 3.5 SP14.1 was installed successfully.
Should I send request to Wago or this issue is already known?
Best regards,
Arv
Author:  sumkrnboy [ Thu Apr 11, 2019 11:17 pm ]
Post subject:  Re: PFC200. Firmware ver 12 with Codesys 3.5 SP14.1. ipkg not found
This is already a known issue.
It seems that a solutions is being worked on.
https://www.phpbb.com/
