I have ARRAY [0..iReceivedData] OF BYTE where iReceivedData (UINT) is around 769 - depends on answer that is send by sensor. So i want to break up this array to more arrays. Is that possible? I want to break it where the value 32 is (that means space, so its space between the data parts). That is why i need to found value 32 in array and need to know its position. Anyone knows how to find that? so i will have aprox 30 arrays at the end and each represents specific information.
Hope someone has an idea.
Thank you.
NbMaxSubArrays :=UPPER_BOUND(ptArray,0);//ClearpointerandlengtharrayFORindex:=0TONbMaxSubArraysDO
  ptArray[index]:=0;
  LengthArray[index]:=0;END_FOR//FillpointerarrayStartPosition :=0;EndPosition :=0;CurrentSubArray :=0;FORindex:=0TOiReceivedDataDO
  //Onlywhenwefindtheseparator
  IFByteArrayBuffer[index] =32THEN
    EndPosition :=index;
    ptArray[CurrentSubArray ]:=ADR(ByteArrayBuffer[StartPosition]); // Pointer to the first byte
    LengthArray[CurrentSubArray ]:=EndPosition-StartPosition+1; // Length of the array (count of elements)
    CurrentSubArray :=CurrentSubArray +1; // Use next record in sub array we are saving those records in
    StartPosition :=index+1; // Update start position
    //protectoverflowingpointerbuffer
    IFCurrentSubArray>NbMaxSubArraysTHEN
      EXIT;
  END_IFEND_FOR
Unless you have to copy your data to save it from a change, I would just define pointers to every sub array. This will save memory and computations.
dFx hat geschrieben:
to find "32", just use a for loop :
  ptArray[index]:=0;
      EXIT;
  END_IFEND_FOR
Hello, Thank you i will try that.
I asumme that ptArrapt is pointer po my new array and ByteArrayBuffer is my data array?
Josep M. Rams hat geschrieben:
You can substitute 32 by 0 in all array. Afteer tath you can:
Str1 :pointer to string;
If pos[index]=0 then str1:=adr(arr[index+1]) end_if
Sent from my Moto G (5S) Plus using Tapatalk
Thank you.
But i can not change 32 with 0 because i have also Nulls in my array that are important for me. but i can say pos[index] = 32, or? What is pos?
Thank you.
Thank you.
Pos would be your input array. I was thinking that your input array be an group of strings separated by number 32...
Sorry
You're assuming right.
Can anyone help define the VARS for this program?
I am a noob
