I'm working on a project that requires uploading the physical configuration of the devices from file and applying it to those present in the project. I think I have found a solution: to achieve this it is necessary to be able to modify, at the start of the plc, the AutoInc Address value (see "second image"), an editable field if the autoconfig master/slave of the EtherCAT_Master is disabled (see "first image").
Is it actually possible to modify by code these values? Do you have any example projects?
Kind regards.
Kind regards.
