ich habe eine CODESYS anwendung , in der ich bei einer Modbusverbindung den "Write Offset" programmatisch ändern möchte z.B über eine WebVisu.
Hat einer eine Idee, wie das funktionieren könnte?
I have a CODESYS application in which I want to programmatically change the "Write Offset" in a Modbus connection, for example via a WebVisu.
Does anyone have an idea how this could work?
Greeting Georg
Serialcom lib allows you to code every read/write and port open/close.
The scanner is simpler and easier because it does this automatically. But it's less flexible.
2019-03-12
When you have brought in the ModbusMaster, the IoDrvModbus library is automatically used.
In here is an FB ModbusRequest which lets you choose the slave, function code and offset/size of data.
I'm never too sure of the best way to get the hComPort parameter...maybe you'll find it
Gruß Georg
XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
Greeting Georg
I would not use the scanner for this.
Use CAA SerialCom lib. https://help.codesys.com/webapp/idx-CAA_SerialCom-lib;product=CAA_SerialCom;version=3.5.12.0
how should that work with the CAA SerialCom lib?
How can I change the offset of the Modbus connection?
