It is currently Thu Oct 24, 2019 5:12 am
PostPosted: Tue Feb 26, 2019 10:02 am
Hi
I'm starting with a clean PFC200 project.
Then I add the CanOpen manager and a slave with the eds file from the vendor.
I have changed the Node address of the slave to the right one.
And after downloading I get the following errors
CanBus status.: Bus failure
CanOpen status.: Bus failure
My slave.: Bus failure
Do I need to tell somewhere what port in the PFC200 I use? I Have a Wago 750-8203 Can Controller with only one serial port.
thx Jesper
PostPosted: Tue Feb 26, 2019 11:19 am
see the screenshot... for more debug information you could add
CANOPEN_DEBUG as compiler define.
Then check the plc logger for detailed information on the CAN startup.
PostPosted: Tue Feb 26, 2019 12:11 pm
Hi Edwin.
Danke für deine antwort.
I have changed the Network id to.: 0 and the baud rate to .: 125 the specification from the vendor see below.
Now the CANBus is running, but on the manager I get.: Not running and on the slave i get .: Module not found.
I have checked the wiring and everything can you see what the problem can be?
Our CANopen interface specification is as follows:
CAN interface : 2.0B, ISO 11898
Baud rate : 50 kbits/s…..1 Mbits/s (default 125 kbits/s)
CANopen Node-ID : 1...126 (default 32)
CANopen Communication profile : CiA DS 301 Version 4
CANopen device profile : CiA 401 Generic I/O module
LSS support : Remote node-ID and baud rate configuration
CAN status indication : Two LEDs (R/G)
CAN termination : On/Off (default Off)
TPDO transmission rate : 50ms (default)
Default baudrate : 125Kbaud
Default CAN-ID : 32
PostPosted: Tue Feb 26, 2019 3:37 pm
seems that this slave does not respond on the object 1000 request…
Is this not a CANopen conform slave?
Does rightclick on CANOPEN Manager and scan lead to found slave?
PostPosted: Tue Feb 26, 2019 4:18 pm
Hi Edwin
Yes, it's a CanOpen slave.
And I tried the scan but the scan didn't find the device. And still, the Manager status is Not Running.
PostPosted: Tue Feb 26, 2019 7:37 pm
if the slave is CANopen compliant - it should have object 1000 and should
reply on the request for this, if not how should the scan then work and even the startup work
this is mandatory to have.
