Library and external variables
GUI
2019-02-13
2019-02-15
  • GUI - 2019-02-13
    Hello
    is it possible from a library to access an external variale (declared on the application, not on the library itself) ?
    on "C" programming it is used the "extern" keywork, to define a variable that is external to a library (and so linked later, when library and main application are put together)
  • dFx
    dFx - 2019-02-14
    You can link a variable from another Library.
    You can also define a pointer that should be initialized to point on that value.
  • GUI - 2019-02-14
    yes, for sure ... I can do it with a pointer but have to initialize it !
    I also already use variable from other library ....
    is it possible to do without a pointer ?
    I tried to use in the library
    VAR_EXTERN
    a: INT
    and "a" is defined on the application
    It seemed something similar to "C" ... (extern int a) but it has not same intent ... it generate an error anyway.
    it would be good to have a sort of library that is just CODE ATTACHED to the main application, so with possibility to call any variable or function too.
