Please take care with pointer and reference assumptions - as was warned by others regarding memory locations! The following screenshots show issues in the idea that a list of BOOLs will be where you expect them:
This was at first build and download - note the huge gap between Bool1 and Bool2 (so reading one memory location after Bool1 would be complete garbage!):
This was after I added another BOOL and performed an online change - notice Bool3 is spaced 4 bytes after Bool2:
This was after I performed a clean and download - note that Bool3 is now moved relative to the online change (and is as one would "expect" - at 1 memory location after Bool2):
If you are going to use a solution using POINTER TO or REFERENCE TO, please know that online changes can sometimes move variables and FBs around in memory, breaking those pointers (point to the old location, not the new one) - refresh the pointers to avoid online change problems (you can avoid online changes, but somebody else using your code may use online change...). I am pretty sure REFERENCE TO has the same problem with online change, since behind the scenes a REFERENCE TO is a special handling of POINTER TO.
Good luck!
