It is currently Tue Apr 23, 2019 3:10 pm
PostPosted: Sun Jan 20, 2019 11:14 pm
I've really struggled to find a way to do this but I cant seem to get it to work.
I want to get the minimum value from X amount of INT variables but not if its 0.
Theese are the once Ive tryed (and countless variations with <> 0 and so on):
Lets say the values are Var1 = 3, Var 2 = 5, Var3 = 0 and Var4 = 10
NewVariable := MIN(Var1, Var2, Var3, Var4);
This gives me the value 0.
NewVariable := LIMIT(1,(MIN(Var1, Var2, Var3, Var4)),15);
This gives me the value 1.
The value i really want is 3, which is the lowest value that is NOT 0.
PostPosted: Mon Jan 21, 2019 5:43 am
A little brute force but you could do something like this.
Define a variable for the minimum value
MinVal: int := 32000;
IF Var1 <> 0 THEN
   MinVal := Min(MinVal,Var1);
IF Var2 <> 0 THEN
   MinVal := Min(MinVal,Var2);
IF Var3 <> 0 THEN
   MinVal := Min(MinVal,Var3);
IF Var4 <> 0 THEN
   MinVal := Min(MinVal,Var4);
IF Var5 <> 0 THEN
   MinVal := Min(MinVal,Var5);
If you put the values in an array, then you could loop through it in a FOR loop.
nOrM
nOrM = Norman Dziedzic Jr.
PostPosted: Mon Jan 21, 2019 8:58 am
Thanks, that almost worked. But I want the MinValue to be at 0 value until 1 or more of Val1-5 goes over 0, then i want MinValue to have that value...
Maybe I should start to look for a diffrent solution.
Iam making an elevator for school, and Ive added a second elevatorcar and I want the it to go down
to the lowest floor as soon as 1 of 5 variables becomes active. If the MinValue is 0 the elevator stops.
PostPosted: Mon Jan 21, 2019 1:11 pm
MinValueNonZero := 0;
FOR index:=1 TO 4
 IF ElevatorBtn[index] > 0 THEN
  IF MinValueNonZero = 0 THEN
     MinValueNonZero := ElevatorBtn[index];
  ELSE
    IF MinValueNonZero > ElevatorBtn[index] THEN
    END_IF;
  END_IF;
 END_IF;
END_FOR;
EDIT 2019/01/24 : Correct fix for first value
PostPosted: Wed Jan 23, 2019 3:45 pm
dFx wrote:
FOR index:=1 TO 4
  END_IF;
 END_IF;
END_FOR;
Genius :D
I solved it by using a whole bunch of IF statments but I will change that för this. Thanks!
PostPosted: Thu Jan 24, 2019 3:05 pm
Edited my code
Users browsing this forum: Vijolica555 and 5 guests
