It is currently Sun Feb 17, 2019 11:10 am
 Post subject: Sqlite Trend Values
PostPosted: Wed Jan 16, 2019 11:12 pm
I have a trend saving values and I made a copy of the SQlite file and loaded it into SQlite Studio. I understand the TS is epoch value in seconds which makes sense when I put it through a converter. My value 2 and value 3 are boolean, which makes sense. What isn't making sense is my Value 1. It's reading a real variable that is a temperature value. But it isn't making sense to me.
For instance it has a value of 1076546816 for something that should be between 2 and 4 degrees C.
How should I go about converting this?
Here is the SQlite file.
 Post subject: Re: Sqlite Trend Values
PostPosted: Thu Jan 17, 2019 8:08 am
In fact the TS value uses a higher resolution seconds. The trend recording encodes all values into a column of integral type and therefore real/lreal values cannot be directly interpreted from that column. To convert that values the value has to be put into a 8 byte binary value and then reinterpreted as real/lreal (respecting the byteorder of the recording device).
The documented way of reading a trenddatabase would be using the according API from the library VisuTrendStorageAccess. An according example can be found with the CODESYS Store: https://store.codesys.com/trend-api-example.html
PostPosted: Thu Jan 17, 2019 5:02 pm
Ah, thanks Edwin.
