It is currently Thu Jun 20, 2019 12:17 am
PostPosted: Tue Jun 04, 2019 12:22 pm
Using dot operator of a struct property is not supported, which makes the property painful to use.
I see no reason why this is not supported.
The dot operator can be used directly on the return value of a method by typing the method name twice (which is suggested by the auto complete).
Another maybe unrelated point: why the private local data of a function block can be read from outside?
Shouldn't the compiler prevent it?
Following is an example to make my point clear:
PostPosted: Tue Jun 04, 2019 3:59 pm
if you are missing the SmartCoding functionality for dots, check settings at Tools-->Options-->SmartCoding..
PostPosted: Thu Jun 06, 2019 7:03 am
He is clearly missing the feature of directly using a struct member of a struct property.
IF _fb.structProperty.xStructMember = TRUE THEN
    // do something
END_IF
However, using a member of a struct of a method return value does NOT work for me as well.
IF _fb.structMethod().xStructMember THEN
    // do something
END_IF
PostPosted: Mon Jun 10, 2019 4:43 pm
IF fb.Prop.xBool THEN
   // something
END_IF
Indeed dosent work;
Quote:
C0185: It is not possible to perform component access '.', index access '[]' or call '()' on result of function call. Assign result to help variable first.
PostPosted: Tue Jun 11, 2019 7:44 am
You are correct.
Return value of a method normally also does not work.
However, by typing the method name twice, which is suggested by the code auto complete, it shows no error any more.
I just attached an example.
    // do something
END_IF
    // do something
END_IF
PostPosted: Tue Jun 11, 2019 7:45 am
Thank you for your reply.
But that is not my point.
PostPosted: Sat Jun 15, 2019 7:54 pm
This works. Beware that the property is writeable doing this (Set-property not needed)
PostPosted: Mon Jun 17, 2019 12:38 pm
Thanks for the workaround.
Hope 3S will provide an official support.
