It is currently Sat Apr 20, 2019 1:17 pm
PostPosted: Wed Nov 28, 2018 2:01 pm
Hello
I have a generic service running reading a parameter. It can read the parameter once, then it won't go again because the 'IF xDone then' runs which makes it finish the sub routine. I need to do a cold reset to get it to work again.
I found a reset() function which seams to do nothing. The documentation says:
Quote:
This function block is used for calling the reset service of a specific instance of a CIP object. The exact effect of this service depends on the CIP object (refer to the CIP specifications (Vol. 1 and 2). This instance call resets the DEVICE_123_ETHERNET device as soon as xExecute yields TRUE:
Sub routine:
IF Execute THEN
   Done                  :=FALSE;
   Read_Parameter_TxData[17]   :=DriveAddress;
   Read_Parameter_TxData[10]   :=WORD_TO_BYTE(ParameterNumber);
   Read_Parameter_TxData[11]   :=WORD_TO_BYTE(SHR(ParameterNumber,8));
   Read_Parameter(
      itfEtherNetIPDevice      :=EthernetAdapter,
      eClass               :=Read_Parameter_Class,
      dwInstance            :=Read_Parameter_Instance,
      wAttribute            :=Read_Parameter_Attribute,
      eService            :=Read_Parameter_Serv,
      pWriteData            :=ADR(Read_Parameter_TxData[0]),
      udiWriteDataSize      :=SIZEOF(Read_Parameter_TxData),
      pReadData            :=ADR(Read_Parameter_RxData[0]),
      udiReadDataSize         :=SIZEOF(Read_Parameter_RxData),
      xExecute            :=TRUE,
   counter:=1;
IF Read_Parameter.xDone THEN
   returnValue      :=   SHL(BYTE_TO_WORD(Read_Parameter_RxData[1]),8) + Read_Parameter_RxData[0];
   Execute         :=    FALSE;
   Done         :=   TRUE;
   counter         :=   0;
   Read_Parameter.xExecute := FALSE;
IF counter = 2 THEN
   Execute:=TRUE;
   counter:=0;
IF Read_Parameter.xError AND counter = 1 THEN
   ErrorEnum := Read_Parameter.eError;
   Execute   :=    FALSE;
   counter := 2;
Error:=Read_Parameter.xError;
Main:
IF IDL_ReadBool THEN
         IF RParmEIP.Error THEN
            RParmEIP();
         ELSE
         RParmEIP(
            EthernetAdapter     :=OPC_2_ETHIG_IN,
            ParameterNumber  :=IDL_ReadP-1,
            Execute          :=TRUE,
      IF RParmEIP.Done THEN
         IDL_ReadBool   :=FALSE;
         IDL_ReadVal      :=RParmEIP.returnValue;
         RParmEIP();
PostPosted: Wed Nov 28, 2018 2:39 pm
If you don't call your FB "Read_Parameter", how should xDone (FB output) come to false ?
Your FB should be called at every cycle.
exemple, slightly edited to auto cycle com requests
Read_Parameter(
  xExecute            :=NOT (Read_Parameter.xError OR Read_Parameter.xDone),
IF Read_Parameter.xError THEN
Regards,
dFx
PostPosted: Wed Nov 28, 2018 2:51 pm
Ah thanks, so glad it was that simple!
