It is currently Mon Jan 27, 2020 4:38 pm
PostPosted: Fri Nov 23, 2018 4:26 am
Dear ALL,
Here i have a problem of CANopen Device(slave) in codesys, hope you all can give me some suggestions,thanks.
One micro controller from MKT is used as a CANopen slave, and in codesys i configured CANbus and CANopen Device (CAN LOCAL DEVICE) , then i edited the Nodeid and I/O area in CANopen deive(see configuration.jpg).
Then i found that the Access Type of RPDO mapping Entry parameters (e.g 0x1601:16#01,see accesstype.jpg) is const, my question is : is it possible to change this access type from const to rw?
Another question is : can i directly use the function EncodePDOMappingEntry for the OD mapping instead of configure OD in CANopen device?
IF(xEnable = FALSE)THEN
   xEnable := TRUE;
   (*enable rxpdo cob-id mapping and entry*)
   pdoCobidEn[0] := _3SCSS.EncodePDOCOBID(xEnabled := TRUE,xExtendedID := FALSE,xRTR := FALSE,dwCOBID := 16#203); (*cob-id of 0x1400*)
   pdoMapEn[0]   := _3SCSS.EncodePDOMappingEntry(wIndex := 16#21CC,bySubIndex := 16#02,byLength := 16#20);
END_IF
Thanks.
Kind regards/ Mit freundlichen Grüßen,
Liu Yanhua
Users browsing this forum: S1ack and 8 guests
