It is currently Sun May 26, 2019 2:27 pm
PostPosted: Tue Nov 20, 2018 2:23 pm
I want to write a string to a file from a specific position. I use SysFileSetPos() from SysFile library to set the position. The thing is it works only when you open the file with write mode, and with write mode, It meanwhile overwrites the original content. I tried to use Append mode, but it always write to the end of the file.
So Is there any better solution for this. :D
   sTitleVersion := CONCAT(sTitle,'0.0.0.0');
   sTitleVersion := CONCAT(sTitleVersion,'"');
   hFile := SysFile.SysFileOpen('/app/service/codesys/info.json', SysFile.ACCESS_MODE.AM_APPEND, pResult:= ADR(udiPosError));
   udiPosError := SysFile.SysFileSetPos(hFile,23);
   SysFile.SysFileWrite(hFile, ADR(sTitleVersion), INT_TO_UINT(STANDARD.LEN(sTitleVersion)), pResult:= ADR(udiPosError));
   SysFile.SysFileClose(hFile);
PostPosted: Tue Nov 20, 2018 4:39 pm
If you need to modify your file data, access_mode should always be write.
Then, your problem is about inserting some bytes in your filestream at specified position.
You may then create a new file, write the part of your file before the position where you will insert. Then write your new data, then write the lasting data from previous file.
Delete old file and rename new.
That's no point elegant but may solve it.
