It is currently Sat Apr 20, 2019 1:18 pm
Post new topic  Reply to topic  [ 10 posts ]
 Post subject: IF NOT AND question
PostPosted: Tue Nov 20, 2018 1:50 am
Could you please explain why the following statement is always FALSE:
IF PLC^.xInitDone AND NOT PLC^.xError THEN
It runs on RaspberryPi with the latest Codesys Runtime.
PLC is a pointer to ModbusSlaveComPort.
The xInitDone is TRUE, xError is FALSE.
If I rewrite the code in such way it works as expected:
IF PLC^.xInitDone THEN
   IF NOT PLC^.xError THEN
 Post subject: Re: IF NOT AND question
PostPosted: Tue Nov 20, 2018 10:01 am
What is the result if you replace dereferenced pointers by only boolean variables ?
PostPosted: Thu Nov 22, 2018 11:26 am
Hello Sir,
ST checks for all the conditions and does not stop early.
AND_THEN does what you describe with nested ifs.
Best regards,
Marcel
PostPosted: Thu Nov 22, 2018 10:17 pm
It works as expected.
m.prestel wrote:
Hello Sir,
Best regards,
Marcel
Sorry Marcel,
I didn't understood your idea.
PostPosted: Fri Nov 23, 2018 8:49 am
and if you try :
IF PLC^.xInitDone AND NOT (PLC^.xError) THEN
PostPosted: Fri Nov 23, 2018 9:03 am
Sorry I misunderstood you...
Can you provide a small example application to easyly reproduce?
Best regards,
Marcel
PostPosted: Mon Nov 26, 2018 1:00 am
dFx wrote:
and if you try :
Unfortunately it doesn't help. Only nested IFs works fine.
For those who want to reproduce it:
FUNCTION write_value_bool : BOOL
VAR_INPUT
   PLC         : POINTER TO ModbusSlaveComPort;
        write_value_bool:= TRUE;
ELSE
        write_value_bool:= FALSE;
And yes, you have to wait for xInitDone to become FALSE or xError TRUE. For this purpose you can do xReset:= TRUE (at ModbusSlaveComPort) for one cycle.
PostPosted: Mon Nov 26, 2018 8:53 am
PhilipLykov wrote:
… xInitDone to become FALSE or xError TRUE...
This does not match written code. Written code says you have to wait xInitDone to TRUE AND xError to FALSE.
PostPosted: Mon Nov 26, 2018 9:13 pm
VAR_INPUT
ELSE
One should avoid the above IF THEN statements. A better solution could be;
write_value_bool := PLC^.xInitDone AND NOT PLC^.xError;
Which (better) readable is something like;
FUNCTION xWrtRdy : BOOL
VAR_INPUT
   pMbCom : POINTER TO ModbusSlaveComPort;
xWrtRdy := pMbCom^.xInitDone AND NOT pMbCom^.xError
Now your code is more atomic in nature and "what's in a name". Also, this function can very easily be transformed to a method of some FB.
https://forge.codesys.com/u/aliazzz/profile/
(Scroll down for my projects)
Users browsing this forum: Andreas Kehrer and 4 guests
