Author |
Message |
Triodes
PostPosted: Tue Oct 30, 2018 3:21 pm |
A couple for times now I've opened an old project, wanting to check some things on-site and gotten the prompt that a download has to be made and the PLC will be stopped.
I've made no changes to the software and it's a hassle to have to shut down the entire system just to go online because the software does not detect a matching compile.
Is there a way to ignore this and just go online without a full download?
I don't remember old versions (2.x) of codesys behaving like this, so I might be missing a setting somewhere since going to 3.x
Top |
dFx
PostPosted: Tue Oct 30, 2018 3:47 pm |
Offline |
Frequent User |
Make sure you created a startup application before leaving online mode (if you done changes after a full download).
Top |
Triodes
PostPosted: Tue Oct 30, 2018 3:48 pm |
"Create Boot project" is always selected on the download screen. I take it that should handle it on it's own?
Top |
dFx
PostPosted: Wed Oct 31, 2018 10:12 am |
Offline |
Frequent User |
On a download, for sure. But If you do an online edit, it doesn't do a boot project unless you've set the option to do so.
Top |
Triodes
PostPosted: Thu Nov 01, 2018 12:14 pm |
That option is in the online edit popup as well and checked.
Top |
