It is currently Mon Feb 18, 2019 2:51 am
PostPosted: Mon Oct 29, 2018 12:21 am
Hello:
I'm starting with Codesys 3.5. SP13. I have installed tCodesys in windows 10 Home and when I try to simulate the proyect and make "login" , the system show this message:
"You are currently not authorized to perfom this operation on the device. Please enter the name and password of and user account which has got sufficient rights."
What should I do?
Thanks in advance.
PostPosted: Tue Oct 30, 2018 3:44 pm
Had this popup before because I enabled security on my project/device -> Use the pass you defined.
PostPosted: Wed Oct 31, 2018 5:02 pm
Thanks for the reply. But I do not have project security enabled. I have tested the same project in a virtual machine with windows 7 and the project is simulated and started correctly once you login. The message does not logically appear.
Thanks in advance.
PostPosted: Mon Nov 05, 2018 11:35 am
May you have previously locked your simulation device with a previous download ?
PostPosted: Fri Nov 09, 2018 7:16 pm
No. I haven't locked my simulation. It's the first time that I try the simulation program.
Another suggestion please?
Thank you very much.
PostPosted: Sat Nov 10, 2018 7:54 am
I would just start the plc on your CODESYS PC and login to this... this offers a lot more possibility in compare to the Simulation.
(Sure your project should then have Control Win or Control 64Bit Win plc in the device tree)
-> Update device by rightclick in the device tree to the plc
Then please do a scan of this local plc and login to this.(Control Win)
To remove the user management from your Simulation project - try to do:
rightclick in the device tree in the simualtion project and -> reset origin device
PostPosted: Sun Nov 11, 2018 11:21 pm
I had the same issue, nearly gave up, anyways try this.
User: Administrator
PW: Administrator
Regards Thomas
Sent from my iPhone using Tapatalk
PostPosted: Tue Nov 13, 2018 2:26 am
Works, thank you...
