It is currently Wed Feb 20, 2019 10:21 pm
 Post subject: Dynamic Alarm Message
PostPosted: Sat Oct 27, 2018 3:42 pm
Hi There,
I am wondering if it possible to configure an alarm message string dynamically.
What I mean by this is in the alarm configuration, I want to have the message display a string from a text list dynamically at runtime.
Does anyone know how to achieve this?
Cheers,
Louis.
PostPosted: Mon Oct 29, 2018 9:55 am
Hi Louis!
I don't know, if there is a way directly in the alarmmanager. I would solve it with a short piece of program, like this:
   asMessageText:      ARRAY[0..8]OF STRING := ['No Message', 'Message 1', 'Message 2',
                                     'Message 3', 'Message 4', 'Message 5',
                                     'Message 6', 'Message 7', 'Message 8'];
   sAlarmMessage:      STRING;
IF byPowerPackEStopDiag <> 0 THEN
   sAlarmMessage:= asMessageText[byPowerPackEStopDiag];
In the Alarmconfiguration you can use <LATCH1> as a placeholder for the text:
Maybe this helps?
Good luck
Alfred
PostPosted: Wed Oct 31, 2018 5:00 pm
Thanks for the reply,
Yes I ended up doing this (something very similar), In theory it should work fine as the documentation says you can define a STRING as a latch variable. I tried it in the simulation but it would not display the STRING value. I also tried a unicode WSTRING with no success. I will try this method once I have some hardware in front of me to try it on.
Thanks for your help.
Regards,
Louis.
PostPosted: Wed Oct 31, 2018 9:48 pm
Dear poster,
I tried the of the dynamic string alarm texts via <Latch1> and it works wonderful in v3.5.11.50 based hardware.
Thanks for sharing!
PostPosted: Wed Nov 07, 2018 3:20 pm
Hi Hermsen,
Much appreciated!
Regards,
Louis.
