It is currently Mon Feb 18, 2019 2:59 am
PostPosted: Thu Oct 25, 2018 1:45 pm
i am looking for information about persistent variables. I made a program which declare some persistent variables. Everything work fine and when the device shutdown and restart, the variable are indeed persistent in the right way. When i change the program (not the PersistentVars) and upload the new program to the device, the persistent variables are not restored as expected : not always, depending on the modification i made to the programe.
I had try a lot a things but do not understand why when i made a change to the program, sometime the persistent variables restart from 0 (persistent lost) and sometime the persistent variables keep its latest value. When exporting in OpenXML, i saw that sometimes tags "Checksum_Type" and "checksumnoinit_override" are added.
Does someone can help me understand if this behaviour is correct or not ? Does someone know the meaning of the tag "Checksum_Type" and "checksumnoinit_override" ?
<globalVars name="PersistentVars" retain="true" persistent="true">
<variable name="_A">
<type>
<DINT />
</type>
<initialValue>
<simpleValue value="0" />
</initialValue>
<addData>
<data name="http://www.3s-software.com/plcopenxml/attributes" handleUnknown="implementation">
<Attributes>
<Attribute Name="Checksum_Type" Value="3401061445" />
</Attributes>
</data>
</addData>
</variable>
<addData>
<Attributes>
<Attribute Name="checksum_override" Value="2196742183" />
<Attribute Name="authentification" Value="d433c4d1-208a-4b7a-b4ba-e3c77e67e46b" />
<Attribute Name="vfinitonly" Value="" />
<Attribute Name="dummy" Value="0" />
<Attribute Name="checksumnoinit_override" Value="2363421397" />
</Attributes>
</data>
</addData>
</globalVars>
PostPosted: Wed Oct 31, 2018 1:46 pm
<initialValue>
</initialValue>
This forces your value when downloading with rebuild all.
Just don't rebuild all, or update your initial values.
PostPosted: Mon Nov 05, 2018 2:35 am
Thank. Do you know if there is some documentation about these XML tags ?
PostPosted: Mon Nov 05, 2018 7:03 am
which device and which version are you using?
If the retain/persist vars do not work reliable try to solve the root cause... there is not need to Workaround
by any XML file ( even I think this is not possible)
