Why not wrap your array with an fb with methods add set and remove?. You can pass the entire fb as var_inout parameter, in this case you are passing the array and his limits to the user.
Sent from my Moto G (5S) Plus using Tapatalk
I have a function which passes a variable array [*] as an IN_OUT. But now it gives me an error. Anyone got a suggestion?
Can you give us some more context on your real problem?
What is it what you are trying to achieve?
Hi.
It seems an sintactic problem, but...
