It is currently Sun Aug 18, 2019 6:33 pm
PostPosted: Fri Sep 21, 2018 4:41 pm
Anybody got a work-around or some solution for this?
CfUnit is a free and opensource Unit testing framework for CODESYS
My profile on cForge
PostPosted: Fri Sep 21, 2018 6:05 pm
use Systypes2Interfaces instead.
PostPosted: Sat Sep 22, 2018 12:53 pm
Hi Edwin,
Thanks for the hint. I have replaced "Systypes Interface" for "Systypes2 Interface" and did the same for some other libs/references which i found had this new *2 version.
Also, some new bug popped up, seemingly from the SPI master of RPi package 3.5.13.0, please advice.
Thank you
PostPosted: Sat Sep 22, 2018 1:13 pm
Funny, these errors only occur when simulation is enabled. If simulation is disabled, these errors disappear! => problem solved ..
It almost did the job, but can please explain in short why these libs are named *2?
I can guess at reasons, but rather stick to know why hearing from 3S.
PostPosted: Sun Sep 23, 2018 7:09 am
apperently this is a known bug (at the moment) that in simulation on Raspberry PI and PFC200
you'll see this error.
The reason is: the simulation plc is if you use CODESYS 64Bit ( which maybe >90% of the users are doing) is
a 64bit plc. So the code (your project and our/your drivers ) should be 64bit capable.
That need to be fixed in this case on CODESYS side.
SysTypes2 have been introduced for the 64bit plc's so we strongly recommend to write platform independet code which could run on 64Bit and 32bit Systems this measn all libs and applikationen should use SysTypes2 Library. ( not CmpError)
This '2' is due compatibility reasons it is an Interface library which will pulled with newest.
The second point you Need to take care on to be 64bit and 32bit capable is to use
the datatypes __XWORD, etc...
There will come up an article in the new faq shortly.
PostPosted: Sun Sep 23, 2018 7:22 am
Hi Edwin,
Thank you for the explanation! As I am not a system integrator, I don't have access to the Jira.
Maybe you guys have some other way for us to look into the Jira? That will save you a lot of work ;-)
Thank you!
Aliazzz
PostPosted: Fri Jun 28, 2019 7:54 am
Hello Edwin
Where I can find this promised faq.
Please send a link
THANKS
