It is currently Mon Jun 24, 2019 5:13 pm
PostPosted: Wed Sep 19, 2018 1:02 pm
Hello ,
I Have Discovered Issue(not really but its not good too) In Old Code That,
IF Any one of the Variable is Changed
THEN writetable :=True
it means Every single time it will go and write value in table, I want to improve that in some better way.
If Any one Could suggest Anything it will be great. :D
Thank You
PostPosted: Wed Sep 19, 2018 8:33 pm
Please explain your purpose/problem a bit more, some more information on what you are trying to achieve would be welcome :wink:
(Scroll down for my projects)
PostPosted: Thu Sep 20, 2018 5:44 am
hello Aliazzz,
I explain The problem here :
if at least one parameter changes, send parameters table to Database
IF( (
mParameter1 <> pParameter1 OR
mParameter2 <> pParameter2 OR
mParameter3 <> pParameter3 OR
mParameter4 <> pParameter4 OR
mParameter5 <> pParameter5 ))
THEN
writetable := TRUE;
END_IF
- I Want To improve this logic because For 5 parameter its okk but Now i have more than 20 so its not wise to call write table everytime.
Thank You,
PostPosted: Thu Sep 20, 2018 3:03 pm
one possibility would be to use a FOR loop and Arrays. Something like this:
VAR
   mParameter : ARRAY [0..ArrayLength] OF INT := [1,2,3,4,5];
   pParameter : ARRAY [0..ArrayLength] OF INT := [1,2,3,7,5];
   counter : INT;
   writetable : BOOL;
END_VAR
VAR CONSTANT
   ArrayLength   : INT := 4;
END_VAR
FOR counter := 0 TO ArrayLength DO
   IF mParameter[counter] <> pParameter[counter] THEN
      writetable := TRUE;
      EXIT;
   END_IF
END_FOR
PostPosted: Thu Sep 20, 2018 3:47 pm
Struct + pointer + mem utils + crc.
PostPosted: Thu Sep 20, 2018 5:14 pm
I'd go with a crc approach as this is way more flexible with regards of your array/tablesize.
If the current crc (of your table) differs from the newly calculated crc then you trigger the writing of the table.
The example @Viacheslav Mezentsev demonstrates this mechanic.
