Instead you can use a more modern approach via a UNION for this kind of operations as it is meant for this.
I'd suggest something like the following example;
2018-09-20
Inside a FOR loop...
StringArray[i] := DINT_TO_STRING(DintArray[i]);
2018-09-21
Originally created by: rickj
If you want to convert the numeric value of each DINT array element then use ph0010421's method. If the DINT array contains ascii data then use Aliazzz's method.
hello ,
I am New In PLC programming And I Need Help.
I have Array Of DINT Which I want to Convert Into STRING Or ARRAY Of STRING , How Can I Do it ?
Thanks a Lot
Anu
more posts ...
see its so simple
no need to use any conversion
codesys is best for this
you just define dint variable at some physical address
define string array on the same address thats it
e.x Dintarray: array[0..30] of DINT AT %MDW100;
Dintarray_STRING: array[0..30] of STRING AT %MDW100;
See CODESYS help on UNION datatypes;
https://help.codesys.com/webapp/_cds_datatype_union;product=codesys;version=3.5.12.0
Hello!
The size of
ardiMyArr
is not 5x4 = 20 bytes?Thanks in advance!
Last edit: Sangchin 2023-12-03
