It is currently Mon Jun 24, 2019 4:39 pm
PostPosted: Fri Sep 14, 2018 2:26 pm
I have several controls (ie motors) running that have a structure for all related tags
TYPE stSensors:
   STRUCT
      EU:          real;
      DU:         word;
      Level_L:      real;
      .. etc
   END_STRUCT
END_TYPE
then use the structure for sensors
   Sensor1:      stSensors;
   Sensor2:      stSensors;
   Motor1:      stMotors;
   etc
When you'd have these tags defined individually you could list an initial value so that it is not zero
Sensor1_LevelHH: REAL := 25.0;
I'd like to do the same with the tags defined in the structure, but the same structure is used several times, meaning I can't define these initial values in the structure definition.
My question: Is there a way to set initial values for each structure instance?
Sensor1.LevelHH := 25.0;
Sensor2.LevelHH := 23.3;
Sensor3.LevelHH := 5.0;
etc.
Thanks!
PostPosted: Fri Sep 14, 2018 3:42 pm
Try something like this:
Poly1: TPolyData := ( coeff := [ 0, 0.1 ], lim := 6553.5 );
Poly2: TPolyData := ( coeff := [ 0, 0.2 ], lim := 6553.5 );
PostPosted: Tue Sep 18, 2018 12:32 pm
Things can be so simple sometimes :) Thank you for that!!!!
Sensor1:          stSensors := (LevelL:=10, LevelH:=90);
