It is currently Wed Jun 19, 2019 7:48 pm
 Post subject: Check class relationship
PostPosted: Wed Aug 29, 2018 3:16 pm
Hi everyone,
Is there a function or way to check whether a class instance is a subclass of a class? Sorry for the alliteration :D
Something similar to issubclass() in Phyton.
Thank you in advance,
Omar
PostPosted: Thu Aug 30, 2018 7:20 am
As far as I know there is no function as easy as issubclass().
But depending on what you are trying to do you might use operator ‘__QUERYPOINTER’.https://help.codesys.com/webapp/_cds_operator_querypointer;product=codesys;version=3.5.13.0
Using querypointer you have to know which sublass you are looking for.
Your base class must implement __SYSTEM.IQueryInterface
I put together the following test of this function a while a go in e!cockpit:
First defined FB_animal, FB_Cat, and FB_Dog
I was then able to test like this:
METHOD MakeSound : STRING
VAR_INPUT
   pAnimal : POINTER TO FB_Animal;
   pCat : POINTER TO FB_CAT;
   pDog : POINTER TO FB_Dog;
   sRespons : STRING;
IF __QUERYPOINTER (pAnimal^,pCat) THEN
   MakeSound := pCat^.Mjau();
IF __QUERYPOINTER(pAnimal^, pDog) THEN
   MakeSound := pDog^.Bark();
If you are testing if an instance of FB_Dog is a subclass of FB_Animal I believe you could define a POINTER TO FB_Animal and use __Querypointer. I have not tested this
IF __QUERYPOINTER(fbDog, pAnimal) THEN
   //It is possible to point to fbDog using POINTER TO FB_Animal. It must be a subclass of animals
PostPosted: Thu Aug 30, 2018 11:09 am
sorry I submitted this by accident.
PostPosted: Thu Aug 30, 2018 11:31 am
Dear alb123,
Thanks for replying. I am confused with your second example, shouldn't it be the other way around like in the first example? My understanding is that it is allowed to point to a child class where a parent type is expected but not the other way around?
I think your example is of no use to me, because in my case the pointer to be checked is not known. More specifically, the reference to be checked (which is initally defined as a reference to a base class) can be referenced to any child class at the implementation and the compiler will be happy about it:
rReferenceToBeChecked REFERENCE TO CLS_BaseClass
IMPLEMENTATION CASE 1
rReferenceToBeChecked REF=clsInstanceOfBaseClass
IMPLEMENTATION CASE 2
rReferenceToBeChecked REF=clsInstanceOfChildClass
At this point what I want is to ensure that the developer has supplied a child class (case 2) and generate an error if otherwise. That is why my intention is to confirm whether rReferenceToBeChecked is a subclass of a CLS_BaseClass.
Omar
PostPosted: Mon Sep 03, 2018 1:32 pm
Hi there,
I changed the approach so that I don't have this issue anymore.
Regards,
Omar
