CAA File library can copy the image you want into the file location which is in your image pool. Change the "Bitmap version" of the Image element to let Visu know it needs updating.
Hi.
I'm trying to load images from a web or a local drive on web visu.
name of the images are not fixed thus cannot be added to the image pool. (i.e. IMG0001_01.tif.... IMG9999_99.tif)
I've tried activeX control and web browers control but both seem not to work on web visu.
is there any workaround?
Hi, did you find a solution?
