A few projects perfectly running under SP12 throw the following internal error at compile time:
Internal error: System.FormatException: the index (zero based) must be superior or equal to zero and inferior to the length of the list of arguments.
I had to switch back to SP12. Any clues on how to fix that ?
sorry for the late answer. There was a bug in the French version back then. I think it has been corrected in the following versions. As a security measure, I am only using the English version from now on.
These kind of you should report on CODESYS store Login -> my question -> bug Report +
example project and stepes to repeat
ok, I'll do
hi ranthony63
Do you have any response on that problem ?
I'm facing this issue too and can't go back to SP12 (No backup, idiot that I am ...) !
I have to clean the project witch can't allow me to modify online (sometimes) ...
François,
