Mapping of Array Element to a EtherCAt Slave variable
Thillai
2018-07-06
2018-07-25
  • Thillai - 2018-07-06
    Is it possible to map array element to a EtherCAT Slave variable. I am trying to communicate with a EtherCAT HMI to read the floating variable. So I need to convert them in codesys from udint to real using arrays and union. I am trying to do with array. But I can't able to map them in I/O Mapping to EtherCAT Slave. Is there anyway I can map the array element to the EtherCAT HMI Variable?.
  • TURCKONE - 2018-07-10
    hello ,
    you can use for loop to transfer entire array from one to another
    for i=0 to 10
    ethecat_variables_array[i]=your_array_you_want_to_copy[i];
    end_for
  • Thillai - 2018-07-11
    My problem is I can't able to map the array elements to ethercat variables
  • TURCKONE - 2018-07-11
    is it possible to attach program?
    how many ethercat variables you need to convert?
    define array in variables list like :
    CH0_RX_Array_Eth AT %QB210: ARRAY [0..29] OF BYTE;
  • Thillai - 2018-07-12
    Hi TURCKONE
    Thank you for your response. It helps me. I am using 256 bytes of read and 256 bytes of write with float as data type.
    I was trying to upload my project. It took long time and not successful.
  • TURCKONE - 2018-07-16
    is it working now ?
    thanks ,
  • Thillai - 2018-07-25
    Yes. It is working now.Thank you for your suggestion.
