Author |
Message |
Thillai
PostPosted: Fri Jun 22, 2018 6:37 am |
Hi, I am trying to communicate with a modbus slave device to read the floating point variable. In Codesys I can see only the option to read as a 16 bit word. How can i read the real value from my slave 32bit floating point variable. I face this problem both Modbus RTU and Modbus TCP
Top |
scott_cunningham
PostPosted: Fri Jun 22, 2018 12:12 pm |
Offline |
Frequent User |
Modbus only supports WORD data transfer. You need to read two registers locations (2 words) and then convert your DWORD to REAL. You also may need to confirm the order of your words, too (upper/lower).
_________________ Scott Cunningham KEB America, Inc. www.kebblog.comwww.kebamerica.com
Top |
ph0010421
PostPosted: Fri Jun 22, 2018 3:45 pm |
Top |
