It is currently Tue Mar 19, 2019 5:50 pm
PostPosted: Wed Jun 20, 2018 11:00 am
Good morning,
I am kind of new to codesys, and on my project I am reading from a Schneider energy meter over modbus/tcp, but the variables that I get are in FLOAT32 format.
As an example, I read the current frequency on the network, that should be around 50Hz, and I get the 16967 value, or 4247 in Hex, which transformed with an online hex to float converter gives me the 49.75 value.
How can I transform the data in codesys?
check attached files,
thanks in advance,
Antton
PostPosted: Wed Jun 20, 2018 10:13 pm
Hello
Create a UNION with members...
AsWord: ARRAY[0..1] OF WORD;
AsREAL: REAL;
Map your Modbus Words to Array members [0] and [1].
Your REAL number will be the Hz.
You may need to swap the map to [0] and [1] if the REAL number is wrong.
Regards
Paul
PostPosted: Mon Jun 25, 2018 12:47 pm
thanks for the reply!
I tried what I think you mean, but I do still read the 16968 value.
Any other suggestion? or may I be doing it wrong?
Thanks in advance,
Antton,
PostPosted: Mon Jun 25, 2018 4:10 pm
A Union is a DUT (Data unit type). See example below. Using the original value you see the float/real value of 49.75
PostPosted: Fri Jun 29, 2018 8:14 am
Correctly read!!
Thanks for the very helpful time you've spent!
