https://forum.codesys.com/
add protecction to a fb or function
https://forum.codesys.com/viewtopic.php?f=11&t=8905
Page 1 of 1
Author:  VICTORSJG [ Thu Jun 07, 2018 5:38 pm ]
Post subject:  add protecction to a fb or function
Hi, how can i add a protection to a fb or function to hide the programm?
thanks
Author:  scott_cunningham [ Fri Jun 08, 2018 1:51 pm ]
Post subject:  Re: add protecction to a fb or function
Are you trying to hide the internal code, hide the whole POU, hide the POU from the SmartCoding display, or other?
Author:  VICTORSJG [ Fri Jun 08, 2018 2:32 pm ]
I want to add a similar know how as tia portal or similar programming software, to avoid see the internal code.
Author:  scott_cunningham [ Wed Jun 13, 2018 1:40 am ]
Put your function or function block in a library, create a compiled library and then your source code is not visible when somebody uses your compiled library. Be sure to keep a copy of the original library, so that you can make changes.
Author:  VICTORSJG [ Tue Jun 11, 2019 3:50 pm ]
Thanks
https://www.phpbb.com/
