Themes are available for the use of the CODESYS Visualization. They are called Visualization Profiles and can be selected within the Visualization Manager. Furthermore, there is a external Editor to create own profiles.
In the new version V3.5SP14 there is a option availible to choose between a dark and a light theme for the text editor
But you can't edit the syntax colors in the codesys options.
But you can edit the colors in the installation path\Codesys\Themes\ in the .editorthemes files.
Just open these files with Notepad and change the colors.
It's a bit complex, therefoere I've created a tool to do this for you and the tool also let's you create new thems: Download (Link Updated 24.04.2019)
Is there such a thing for CODESYS like themes, like DARK, LIGHT etc like some other editors have?
No defined theme, but you could modify settings: Tools -> Options.. -> Text editor (left hand side)
