Little Confused
moggsie
2018-03-20
2018-03-22
  • moggsie - 2018-03-20
    I have declared an FB with VAR_IN and VAR_OUT data types
    I call the FB from a _MAIN having declared the FB data type
    When I call the FB from _MAIN why am I required to provide an Input parameter and not an output parameter ?
    I am sure there is a simple answer to this, but the CODESYS help files do not ( to me at least ) reveal the answer as quickly as one might expect.
    IMG: codesys_fb_query_1.jpg
    IMG: codesys_fb_query_2.jpg
    OK, the input isn't required.
    But it does look a bit like that when you first create the rung ?
    IMG: codesys_fb_query_3.jpg
  • Anonymous - 2018-03-21
    Originally created by: ph0010421
    Just enjoy the fact it doesn't all arguments passing.
    Pp
  • r.evbatyrov - 2018-03-22
    Hi moggsie,
    moggsie hat geschrieben:
    You can remove ??? either.
    Regards
    Roman
  • moggsie - 2018-03-22
    Roman,
    Thanks for the reply
    Yes, the ??? can be removed.
    It's just that I was confused that the output from the FB never prompted for an output parameter, whereas the input parameter looked like it was required ( though in the end not necessary ).
    In fact, it was not even possible to enter an output parameter on the highest output row/position.
    Try it, and you will see what I mean.
    It does not appear to be logical or consistent behaviour, which always makes me think about what else could cause fun.
  • Anonymous - 2018-03-22
    Drag an 'assignment' from the toolbox
    where's that in the online manual ?
    Just asking. I know it's probably in there, but you've obviously a lot more experience than I have.
    Here's a little video to show how "assigments" seem to me behave non-intuitively. I'm sure there's trick, but it's not obvious for the simple-minded.
    fb_assigment.wmv [431.35 KiB]
    To put it bluntly, though I applaud CODESYS for striving to develop an open(ish) platform , it seems to me that there are a few too many "features" that will make this programming environment a niche product. It needs more "polish" before it enters the mainstream.
    That said, TIAPortal, RSLogix, Proworx, Unity et al have all been through this pain. Some are still there
    ( and for balance throw in GE CIMPLICITY Control too ! )
