It is currently Mon Mar 25, 2019 2:46 pm
Post new topic  Reply to topic  [ 9 posts ]
PostPosted: Fri Mar 16, 2018 11:40 am
Hello
I have initiated a function block several times and want to loop through to check for a variable.
VAR CONSTANT
   numOfGensets      : BYTE := 2;
   gen1, gen2      : fbGenset;
   gensets         : ARRAY[1..numOfGensets] OF fbGenset := [gen1, gen2];
END_VAR;
.... Main prog....
gen1();
gen2();
// Loop through all initiated gensets
FOR i := 1 TO numOfGensets DO
   IF gensets[i].breakerStatus() = BREAKER_STATUS.TRIPPED THEN
      tripped := TRUE;
END_FOR
METHOD breakerStatus : BREAKER_STATUS
// Check status of circuit breaker/generator breaker
IF closed THEN
   breakerStatus := BREAKER_STATUS.CLOSED; // Closed
ELSIF NOT closed THEN
   breakerStatus := BREAKER_STATUS.OPEN; // Open
ELSIF tripped THEN
   breakerStatus := BREAKER_STATUS.TRIPPED; // Tripped
This dosent work as desired as gen1 and gen2 isnt updated cyclically in the array.
How should this be done the proper way without having to update the array every scan?
PostPosted: Fri Mar 16, 2018 12:09 pm
program PLC_PRG
var constant
    numOfGensets: byte := 2;
end_var
var
    i: byte;
    gen1, gen2: ton;
    gensets: array [ 1 .. numOfGensets ] of pointer to ton := [ adr( gen1 ), adr( gen2 ) ];
end_var
gen1( pt := t#10s );
gen2( pt := t#20s );
for i := 1 TO numOfGensets do
   if gensets[i]^.pt = t#10s then gensets[i]^.pt := t#55s; end_if
end_for
PostPosted: Fri Mar 16, 2018 4:31 pm
Brilliant, thanks!
PostPosted: Wed Mar 28, 2018 11:23 am
New but similar question.
Assume two FBs where FB_B extends FB_A.
Lets say I have declared some instances of FB_B and a few of FB_A.
How can I loop through all of the declared instances of both FB_B and FB_A to do something thats declared in FB_A?
Question 2:
Is it possible to have a variable shared between declared instances, not beeing in a GVL?
PostPosted: Thu Mar 29, 2018 8:09 am
You can use method FB_init() for this. Online help.
METHOD FB_Init : BOOL
VAR_INPUT
  bInitRetains : BOOL; // TRUE: the Retain-variables are initialized (reset warm / reset cold)
  bInCopyCode : BOOL;  // TRUE  the instance will be copied to the copy-code afterward (online change)
It is possible, but why you need this? (you can use var_stat... end_var in FB_A)
function_block FB_A
var_input
    value: int := 0;
end_var
var_stat
    m_index: int := 0;
    m_instances: array [ 0 .. 1000 ] of pointer to FB_A;
end_var
method public FB_Init : bool
var_input
    bInitRetains : bool; // initializing of retain-variable
    bInCopyCode : bool; // instance is copied to copy-code
end_var
m_instances[ m_index ] := this;
m_index := m_index + 1;
method GetInstAt : pointer to FB_A
var_input
    index: int;
end_var
GetInstAt := m_instances[ index ];
function_block FB_B extends FB_A
program PLC_PRG
var
    bFirstCycle: bool := true;
    f1: FB_A;
    f2, f3, f4: FB_B;
    p: pointer to FB_A;
end_var
if bFirstCycle then
    f1.value := 1;
    f2.value := 2;
    f3.value := 3;
    p := f1.GetInstAt(3);
    if p <> 0 then p^.value := 4; end_if // Check f4.value online
    bFirstCycle := false;
end_if
PostPosted: Mon Apr 02, 2018 9:25 pm
Hmm. Ok. Not sure how to do that.
Reason behind the looping is to monitor the state of a variable in FB_A (aswell as FB_B which extends FB_A). Normally I'd do this as proposed by you in a earlier post, but this dosent work when I also need to include both FB_B and FB_A.
Reasons behind shared variable is because I want a interlock between declared instances. Say FB_A has a method for controlling something external (relay for example) and if any of FB_A (aswell as FB_B which extends FB_A) has this output active none of the others shouldnt be able to actuate the external output.
Maybe you have a better solution to this?
PostPosted: Wed Apr 04, 2018 7:17 am
There is a library with synchronization elements: CAA Types Extern with BOLT and SEMA. To use them you need to know more precisely what you want.
Interlocking - what does this mean in your opinion? How should this work? Other fbs must wait or do nothing or return error state?
PostPosted: Wed Apr 04, 2018 1:31 pm
Each FB has a variable to start a sequence (action), if any of the FBs has say "BREAKER_STATUS.CLOSED" active (from first post), then the others should not be able to activate the closing sequence.
PostPosted: Sun Apr 15, 2018 9:10 pm
Any more tips?
Users browsing this forum: No registered users and 33 guests
